Suggestions??
my pro comp 6" lift has been on for about 3 weeks now. i am hearing rubbing type noises from the rear in the mornings when leaving. there is no way possible the tires are rubbing anything because i can see they have more than enough clearance in way of the shocks, etc. anyone know what i may can check or have this problem too? it makes the noise backing out of the driveway without the shocks even flexing. it doesn't make the noise when driving forward.
possibly the e-brake rubbing, something in the diff... hub bearings... kinda a broad topic! Got anything else we can go on?
Originally Posted by 4.2trimble
(Post 3225481)
yeah... id doubt it would be bearings... however if you offroad it its a possiblity.
Lay under the truck... have a buddy CAREFULLY back it up, that way you can be under it and see if you can find it. Try putting a hand on something you think is making the noise. See if you can "feel" the noise, see if it maybe stops when your hand is on it. These "noise" questions are just aboutt he hardest thing to diagnos online... with out hearing the sound.
