Allignment?
Put some lift spindles on my truck this weekend and everything seemed to be fine when moving forward. But when I back up, the tires (which are 37") tow in really bad. Can this be fixed with an allignment, or will something else need to be done? Thanks in advance.
Jason 2000 F1 |
Bump...anyone?
I believe that is normal.
umm no its not normal
any time you do any sort of suspension mod you should get an alignment |
I took it as he was saying the camber changed as he turned the steering wheel.
Sorry for the confusion, I meant when I back up straight, the wheels dive (toe in) in. But when I put it in drive and start moving forward, the straighten up like nothing is wrong. Also when I begin moving forward from reverse, I here a lot of "popping" and strain be put on the tie rods. Just afraid to drive it now.
sounds like somethings loose
get it to a quality alignment shop and they should be able to tell you what's going on |
I agree.
Originally Posted by 1badstx
(Post 3219626)
its time for new tie rods
