Aftermarket Coilovers for 4" Lift?
Are there any companies that make aftermarket coilovers for a 4" lift? From all the research and searching I've done, it doesn't look like there are any.
If I were to replace my current front coilover/shock setup (4" Rancho lift) with coilovers designed for a 6" lift would it create the same angles as adding a 2" leveling kit on top of my current 4" setup? I'm assuming it would but wanted to make sure. (For those that don't know, the Rancho kit uses longer shocks and spindles to maintain factory ball joint and C/V angles) I'm considering these Sway-a-way coilovers part #56000-1504-6 in this link: http://www.swayaway.com/OffRoadTrucks.php I'm assuming those are the coilovers I would need correct? Best place to purchase them? Thanks for any and all input. |
im not sure how much you want to spend but king can make some for you . I think the only difference is the length of the bottom extension. I think all colis are about the same size just with different extensions. Hope that helps. Im sure some other manufacturers will as well
Thanks for the info black, I may have to look into that.
Camburg has some coilovers to replace the stockers on this page: http://camburg.com/04F150.html It would be nice to purchase these with about a 3" extension on the bottom: http://camburg.com/images/2006%20f-1...50-2xand4x.jpg |
them look nice Copenhagen, any chance they have blue?
Did you ever find an extension? |
