Sponsored by: CARiD
Do I need to re-align?
Old Feb 14, 2008 | 04:25 PM
westcoford's Avatar
Ok, so you guys gave me some great info on the tire size issue.
So I am assuming that if I raise the torsion bars 4-5 turns to make the 33's fit that I have to re-align?
Also is there a special tool need to do this or does some socket or wrench fit?
Thanks for help.
Mike
Old Feb 14, 2008 | 04:27 PM
MmmBuckles's Avatar
yeah. you will need to get an alignment after cranking the torsion bars
Old Feb 14, 2008 | 04:39 PM
NYfordguy's Avatar
I think its 13mm.Socket should do the trick and maybe some PB Blaster.
Old Feb 14, 2008 | 04:52 PM
minimonster17's Avatar
hmm... for some reason i wanna say 15, or even 18mm... can't remember exactly. w/ a breaker bar, i was able to crank the t-bars w/o using any penetrant, however, it was a pita to crank those bitches. spray some pb blaster, and w/ a breaker bar, you'll be set.
Old Feb 14, 2008 | 08:43 PM
westcoford's Avatar
Hey thanks for the info from everybody. This site is great. I am glad I found it.
