Rize Rear shock Q
Now that ive plunked down a ton of money to get this lift done there are problems. . .I guess rize is out of 5150's for the rear and they dont have an ETA to them of at least 3-4 wks. If i go ahead and do 10" of lift in the front and rear wont I need longer ones anyway or will those work? If i need longer ones I could just get a different bilstein then, but if the 5150's will work i think id rather get what i payed for. .:lol: It had to happen to me, put down money, get on a time frame and run into problems. . .thanks for any help guys
What are you planning on running in the rear? I'm running the 6" Block and a 2" add-a-leaf with no problems from the Bilstein 5150s.
The same as you. But if I went the 10" route id like to get a 4" leaf pack. and Im not sure if Ill need a longer shock, I did some searching and it was discussed once but I never gathered if I needed a longer one or not. I think FX4reaction has a diff. shock than the 5150 in the rear
34" extended length and 20" collapsed would work well.:thumbsup:
what are the measurements of the 5150 that come with the rize?
