6" lift not enough!
Old 11-27-2007, 08:14 PM
bone79's Avatar
6" lift not enough!
guys i have a procomp 6" lift, i thought that was enough but i already want more.i just got the lift last week. can i do more to the suspension safely, or will i need a body lift? i would like another 2 or 3 inches. any ideas? thanks
Old 11-27-2007, 08:23 PM
wandell's Avatar
If you have the adjustable coilovers you can crank them up for another inch or two of lift. If you have the standard Pro Comp, you can add adjustable coilovers. If you want any more lift, add a Performance Accessories body lift.
Old 11-27-2007, 10:58 PM
bone79's Avatar
thanks wandell! what about the back to get it up to match the front right now it's sits low? you have been alot of help on the many questions i have had. just new with fords and lifts, thanks again
Old 11-27-2007, 11:15 PM
gators241987's Avatar
stop this madness. lifts are a disease. you will be never satisfied with it. i know. i want to go higher now. but think about it. you will have to regear, new uca's, extend brake line, possibly bigger brakes, bigger tires. there are lots of things that you have to change going from 35's to 37's. stay the way it is, in fact, post pics. ..
Old 11-28-2007, 09:53 AM
supachargd2k5's Avatar
Yeah if you want to go bigger i would go for the the body lift and a new leaf pack maybe in the rear to raise it up.
Old 11-28-2007, 12:41 PM
wandell's Avatar
You can add a taller lift block or an add-a-leaf to the rear, but new springpacks would be best.
Old 11-28-2007, 04:49 PM
bone79's Avatar
wandell, how much do the springpacks run?
Old 11-28-2007, 07:29 PM
achap's Avatar
like the truck, what size lift, rims and tires are you running?
Old 11-28-2007, 07:49 PM
Jditta's Avatar
Probably around 400+
Old 11-28-2007, 09:05 PM
bone79's Avatar
thanks guys!
Old 11-29-2007, 09:53 AM
tnsilverfx4's Avatar
what size tires do want to run ultimately?
Old 11-29-2007, 11:16 AM
6 inch pro comp stage 2 kit, 35 nitto mud grapplers, 20 moto metal 951s
Old 11-29-2007, 01:59 PM
bud8817's Avatar
you have the stage two so crank those coilovers, and get a body lift i dont see why you would need longer break lines you will still have the same amount of down travel as before even if you crank up you coilovers. you dont need breaks but they are nice to have just when ever you need new ones upgrade, and gears arent a thing you need right away, i havent done gears yet i have been lifted for a year. although i am getting gears in about 2 weeks!!!
Quick Reply: 6" lift not enough!
