Will i sit level to people with 8" Rize and 37's
6" Fabtech with bilsteins 5100 and 37 nittos will i sit the same height as people with the Rize.
Or should i go with dirt logics(1.5 Cranked) instead of bilsteins(2.5 cranked)
not sure on the DL but a guy at 4wheelpart told me i would only get 1.5 cranked
not sure what truck you got. but i have a f150 2wd. i have parked next to a 8" Rize on 37's and iam taller by roughly an inch or two, give or take. Its taken me a 6" lift, 3" body lift, and cranked DL's to get to that height. the DL's are cranked 2.5"s so yea the fabtech coilovers can get you there. the rear is a 5" block and 1" shim setup. all this on 36's. be prepared to drop some $$ to get to a 8" rizes height if you are 2wd.
Originally Posted by ThumperMX113
I'm not sure. Bud says the Rize is bigger than 8" so who knows ..
The Dirt Logics can be cranked up to 2.5" though so he doesn't know what he's talking about.
Your talking about Bud
I have a 04 extendedcab FX4 i guess ill go with the fabtech and dirt logics then like in 3 months get some UCA's. thx for the replies.
or better yet buy the nicer bigger kit that comes with new UCA's (CST)!
Originally Posted by bud8817
the rize. is a 9" lift. im not kidding i freaked when i put your strut exstensions in! the spacer for the rize is 8.5" the angle all the way down makes more like 9 1/4" of lift!!! its retarded how much bigger that lift is than what they say it is.
what the f*ck does that mean either your making a reverence about weed.. or your being a a$$hole...
