Help! Notchy RF wheel w/level kit
Hey all,
I have noticed when my truck is up on a lift the right front tire will not spin freely like the left front. It feels notchy. If I use a floor jack on the suspension arm to push it up it gets easier to turn. Almost feels as if the cv joint is binding. I do have an NCD customz 2.5 level kit installed so I took everything apart and reinstalled it with same issue. Anyone have any idea's?
I wouldn't think you would have any binding unless 4x4 is engaged. I haven't paid that close of attention when I've had my truck off the ground. Check to make sure your vacuum line on the CV joint housing is in good condition (no cuts or cracks). Have someone cycle 4x4 off and on and see if it engages and disengages on the hub.
Anyone else have a clue?
