Fabtech question
I'm looking into getting the 6" Fabtech system with DL coilovers and their performance shocks.
I wanna run 36x13.5x20 Irok radials on Moto Metal 951b 20x10 rims. I was wondering if I will be able to fit the 36s ok with no rub. I wanna avoid adding a spacer b/c I hear this messes up the cv angles? If I have to I'll run 35's I was just curious to see if I could jam the 36s in without any problems Any input or info is appreciated. |
Cool, thanks. What backspacing should I get on the 20x10s
You may have to crank up the coil-overs a little, which in the end is doing the same as a spacer, but at least you can control the height.
IMO on BS 4.5" looks good, but they will stick out a little. |
Thanks guys.
They offer a bs of 4.79in in the 20x10 951 so I'll probably go with that. |
Since you want a 36 inch tire on a 10 inch wide wheel with shallow backspacing, I'd suggest the 8 inch Rize lift.
i am running 36x13.50 iroks on a 20x10 wheel w/ 4.5"s of backspacing on my 2WD, iam a little taller than where the rize sits. they clear easily but i know i wouldve had a rubbing problem with only a 6" lift and the wheels i went with. if you go with the fabtech with the DL's i would suggest cranking em up to avoid rubbing, the iroks measure out a little taller than a 36" tire because of the agressive tread design. :smoke:
If you're going to get the coilover fabtech kit you might as well get the RIZE for the same price.
