My options for going bigger?
already have 6"fabtech on 35"s
was thinking about a 3 inch body lift thn putting 37"s, how safe or are there any what effects does a body lift cause. or what else in the blue hell can i do? the guy at the shop by my house said it was way more complicated and time consuming to do a body lift after a suspension lift? makes no sense to me ? what about you guys is he feeding me a load of crap? anyways he said installed and everything it would be about $1,000!! lol sounds ridiculous to me! http://pic15.picturetrail.com/VOL627.../282187085.jpg |
We don't even know what kind of truck this is for ...
thump means what year is it... is if a 4x4, if its a 97-03 you can crank your t-bars, if its a 04-07 the but a coil spacer in the front for 2.5in. Body lifts are fine just get the gap gaurds and you ll be set.
why do u want to go bigger?
Man, if you ask why go bigger, you will never understand.
I'd go with a 3 inch Performance Accessories body lift. |
BIGGER IS ALWAYS BETTER!!!!!!! And don't let anyone ever tell you any different. I've owned a Ram with a suspension and body lift on it. It was good set up. The install on it wasn't that great cause I didn't do it and didn't know that much about lifts when I bought it. I've since installed 2 body lifts on F150's. As long as their installed right and you get the gap guards to hide the space, there safe. I'm thinking about running a 6" Fabtech next summer under my PA 3" BL. If I gave save up the cash. I think you'll be fine and also be very happy. You'll be saving for bigger tires 2 weeks after you put it on. :drool: |
i would get a body lift over a spacer and that price was way to high. beautiful truck by the way love your front end.
didnt you just lift htat why areyou going to get new tires already? i guess if you like spending money but i would stick with the tires you have until they wear out then go bigger. |
yea, i would go with the 3" PA body lift. or get a set of adjustable coilovers and uni-ball UCA's and crank the coilovers up a couple inches and throw a 2" AAL in the rear. or do both and throw on some 38's. i would stay away from adding the spacer. coilovers look much better :smoke:
http://i58.photobucket.com/albums/g2...rBuggyz034.jpg |
thanks for all the great input
yeah i did just get it all put on a lil while ago but i got some one who is gonna by my tires from me....im not tryin to rush it just tryin to figure out how much i need to be saving up for.
i would imagine he said a BL is more difficult to do after a suspension lift because the body is higher off the ground and it will be more difficult to lift to slip the pucks in, with a jack being that high off the ground. at stock height, you can use a large floor jack and a block of wood to lift the body. after 6" of lift already, that jack and block of wood isn't going to reach. they will have to get creative.
