Sponsored by: CARiD
break lines?
Old Aug 21, 2007 | 09:39 PM
Gray Ghost's Avatar
break lines?
i have a 3" body lift on my truck right now and working on adding a 6" procomp suspension lift and MAYBE adding my 2.5" spacers on there too... am i going to have to put longer break lines on there? if so how much?
Old Aug 21, 2007 | 10:12 PM
ThumperMX113's Avatar
Good question. . Bump!
Ask "Animal" He just posted a thread in the 2004+ Forum labeled "Animal got his 40s!"
Old Aug 22, 2007 | 10:33 AM
bigtruck311's Avatar
i would get 8" longer line steel braided
Old Aug 22, 2007 | 03:31 PM
baja150's Avatar
Body lift doesn't have anything to do with brake lines.
A lot of people are running leveling kits on top of their 6" lifts and fully cranked coilovers w/ their 6" lifts and I don't think any of them have replaced their brake lines.
Personally I only have a 6" lift and I bought new stainless braided lines because I didn't want to bend my factory lines and use the drop brackets. I bought them from Top Gun Customz for $117 shipped; they're Rize brand.
Good luck.
Old Aug 22, 2007 | 05:39 PM
Gray Ghost's Avatar
if the break master cylender is bolted on teh body and the lines go to the breaks wouldnt that have something to do with it
Old Aug 24, 2007 | 01:54 AM
2001Screw4x4's Avatar
How about "brake" lines and "brake master cylinder"?
Old Aug 24, 2007 | 12:17 PM
baja150's Avatar
Ok but whatever (if any) brake line extensions that would be required for the body lift would be included with the body lift.
Whatever brake line extensions that would be required for the suspension lift would be included with the suspension lift.
I thought you were asking if you're going to need different brake lines because you're putting a leveling kit on top of a suspension lift.
Old Aug 24, 2007 | 12:39 PM
nooq's Avatar
i got a 6" suspension lift and 3" body lift with my factory break lines. There was enough slack in them to kinda bend them as you go.
Old Aug 24, 2007 | 01:32 PM
BullRing's Avatar
If anything the break lines would come with the lift kit.....just because your adding a body lift what would that have to do with brake lines your just lifting the body of the truck......go outside and look how your lines run.
