just ordered a 2.5 front level
i just ordered a 2.5 front level do i need after market shocks or can i use the factory one's untill i get the money to buy some shocks and when i do what kind of shocks do i need and if any one has a part number for the front and the back shocks thanks
buy the way i have a 2005 4x4 |
No you don't need new shock with a leveling kit. If you think you want to add aftermarket shock go with the Bilstiens or Ranchos that feature adjustable spring preload so you don't need a leveling kit.
thanks and will a 285/70/17 fit on the factory 17 and with the level if so they are next
Since I have a leveled '05 4x4 also, and because I have been debating the tire thing for awhile now, those 285's will fit fine. That's probably the way I will go also (maybe 295's). However, I've also been looking at the BFG A/Tko in 305/65/17.
Several members have fit 35x12.50's (315/70-17's) on 4x4's with leveling kits by using the OEM wheels so you can easily fit 285/70-17's (33x11.50). As a general rule with a leveling kit on the new 4x4's you can fit 35x12.50's by using the OEM wheels or 33 inch tires using wider aftermarket wheels.
