Major Problem with Autospring!!!!
Well Sunday me and my dad installed my 2.5 as and 35's. Truck looked great. I could tell that the truck really needed a alignment!! Took it to my dealer and got it aligned. Well that didnt work! So took it back again today, and they played around with it and still can not get it to stop drifting to the right!! It is really pissing me off!! Any opinions or has anyone else had this problem!!!! Please help!!
Come one anyone this is killing me!! The tech said that is was the leveling kit!!
Take it somewhere besides the dealer, they always look to blame everything on the friggin aftermarket when its usually their incompetance. Stupid question: Did you check your tire pressure??
Checked it. All tire are set at 38 psi! They are load d tires!!
How did you resolve your alignment issue? I am about to go with the same setup as you .
Thanks in advance |
Need to verify one side is not engaged or hanging in 4wd. Also, if you haven't tried, run a mile or two in 4wd then dis-engage. After dis-engaging back up rather quickly. See if this helps.
