For the guys running 38's!!!
Ok im wanting to order my tires tomorrow but im still a little nervous. I have 3" Body already, adding 6" fabtech. Im wanting 38's bad, so im going to order 38x15.50x18. Will I have any serious problems? or Should I quit worrying about it and order the dang things?? :bows:
Just Buy them!! I did the same thing, worried and fretted. I have 38/15.50/17 Mickey thompson MTZ's. I had to put wheel spacers on the front but that is because of the lift knuckles on my kit which is superlift, your's will work fine. Check out BIGTRUCK311's gallery, i believe he has the same set up you have with the fabtech kit, so anyways, order them!!
they will fit just fine you will have to do some trimming, you will also need to cut off the nub on the lower controll arm, but they fit
Hey bigtruck311, thanks for the reply. So is that all the lift you have or do you have more, just curious how it will look. Ok well I was also wondering if it would be ok to stack the fabtech block on the stock block? Im going to odrder my tires today thanks for the help ill keep everyone posted on my progress.
| All times are GMT -4. The time now is 12:20 AM. |
