Help!
Help!
I just had my 3.5 spindle and 1.5 in coil spacer put on but I need new shocks for the front, no one seems to have shocks for a lift so if I can find 4x4 shock will they work on a 4x2? And 4 wheel parts has to order them, which I will do but its my daily driver so the sooner the better.
I think you need standard length OEM replacement shocks. The spindle lifts use OEM shocks and I don't think the coilspring spacer will affect shock length because your front suspension's travel is limited by bumpstops.
I went and looked when the shop called me and they would barely thread in, and I wouldn't of had and travel when the shock had to go up (if that makes since). But I went ahead and just ordered the rancho 5000. Thanks for the help though.
