F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Suspension (https://www.f150online.com/forums/suspension-28/)
-   -   Alignment spec's (https://www.f150online.com/forums/suspension/269311-alignment-specs.html)
TXGSXR1K Jan 18, 2007 10:45 AM
Alignment spec's
I need the latest alignment spec's for my 06 crew cab FX4. I can do the alignment at work, but the Spec's we have for the truck here are wrong. I know there is a TBS out there with some new Spec's but I dont know what they are. Any help would be appreciated.
TXGSXR1K Jan 25, 2007 09:08 AM
ttt
GIJoeCam Jan 26, 2007 07:42 AM
The only thing I found in the TSBs was WRT the the toe spec. (set the front total toe to 0.30 ± 0.05 degrees) But that TSB only applied if the tires were wearing abnormally on the inside edges.
As for the rest of 'em, the chart doesn't copy and paste well...
Caster: Left: 4.5 +/- 1.0, Right: 4.9 +/- 1.0, total/split -0.4 +/- 0.75
Camber: ........ -0.2 +/- 0.75...... -0.2 +/- 0.75............ 0.0 +/-0.75
Total front toe:.............................................. ........... (See above)
Total rear toe:.............................................. ...........0.0 +/- 0.20
Thrust angle (rear)............................................ ....... 0.0 +/- 0.30
TXGSXR1K Jan 26, 2007 05:57 PM
Thanks man. That is just what I needed.
