Need more help
Need more help
will 20x8.5 wheels with 33" tires fit on my 2x4 with my leveling kit(2.5)?? I was going to put a body lift but the manufactor says I cant tow anything if I put it on. Thanks again!!
First of all, you can tow with a body lift. THe only thing affected as relating to towing is you can't use your rear bumper to tow with if you lift it. All you have to do is use your receiver hitch (or install one).
Second, 33's on an 8.5 inch wide wheel will be a tight fit with only a leveling kit. If you go with a 285mm or 305 mm wide tire and use a wheel with 5.5 inches of backspacing, they may fit.
35" bfg mud-terrains with a leveling kit if you want to check it out click on their galleries page go to the bottom and search for 2005 f150 4x4 go to page 4 and look at album my truck,but from what ive read on this web site this set up is hard on ball-joints.This is my truck [IMG]https://www.f150online.com/galleries....cfm?gnum=8090[/IMG]
