Sponsored by: CARiD
Which Gears?
Old Feb 13, 2006 | 08:42 PM
iron_lungs916's Avatar
Question Which Gears?
When It Comes To Cars And Trucks, I Know Absolutely Nothing. I Recently Lifted My 2004 F-150 4x2 With A 6" Fabtech Lift. I Always Read People Upgrading Their Gears. Now, Is That Something I Should Do? What Are The Effects If I Do Not Change Them? What's The Price On Upgrading Them, And When Can I Go To Get Them Upgraded? Thanks In Advance.
Old Feb 13, 2006 | 09:43 PM
ChrisT's Avatar
Did you go up in tire size with the lift? If so, what size tires do you have? I also have a 6" lifted 4x2 and I went to a 33" tire. My stock gears are 3.55LS. I am going to go to 4.10's and was told that will put me back to stock. I got a price of about $500 to $800 and that's just for one axle since we have 4x2's. I would think any local shop can do the gear swap out for you.
Old Feb 14, 2006 | 10:11 AM
bigtruck311's Avatar
there is nothing but pros to doing a gear change if you have gone to larger tires, it will decrease the strain on the tranny caused by the larger tire size it will increase performance and city mpg, if you do not change them it will put more of a strain on your tranny and performance, i recomend 4.56 ratio if you are running 35" tires, good luck
Old Feb 14, 2006 | 12:36 PM
I Am Running 35" Tires. Thanks Guy's. I'll Check Into That This Weekend.
Old Feb 14, 2006 | 12:37 PM
Hey Big Truck...what Did That Cost You? The 4.56 Ratio?
Old Feb 14, 2006 | 12:42 PM
2006marklt's Avatar
4.88 gears - 4 wheel drive - $1300 installed
Old Feb 14, 2006 | 02:56 PM
I Have A 4x2
Old Feb 14, 2006 | 11:55 PM
i am a mechanic i did my 4.88 gears myself so it only cost me parts($200), it would cost you about $500 or so since you are a 4x2, good luck
Old Feb 26, 2006 | 02:23 PM
speeddemon13's Avatar
hey bigtruck311...
hey whats your email address because i want to email you the setup I want and it seems like you know alot about suspention and trucks.
Old Feb 26, 2006 | 04:05 PM
cudacat666@hotmail.com
Old Feb 27, 2006 | 12:35 AM
StngStr's Avatar
Originally Posted by bigtruck311
there is nothing but PROS to doing a gear change if you have gone to larger tires, it will decrease the strain on the tranny caused by the larger tire size it will increase performance and city mpg, if you do not change them it will put more of a strain on your tranny and performance, i recomend 4.56 ratio if you are running 35" tires, good luck
FIXED.
Old Feb 27, 2006 | 09:59 AM
Originally Posted by StngStr
FIXED.
thanks it was late when i typed, i edited my post as well
