Sponsored by: CARiD
Help !!!!!!
Old Jan 17, 2006 | 08:35 AM
mudd1's Avatar
Help !!!!!!
I got a 02 supercrew fx4.. For some reason it squeaks alot went I'm off road, or just going over speed bumps. Deffinantly suspension related. What can I do to stop this? Truck only has 25,000 miles on it..Factory warranty is expired though.. Help !!!!!!
Old Jan 17, 2006 | 10:21 AM
Fordfan4life's Avatar
Got get down and dirty pulling pushing shocks bouncing up and down on the bumpers listening for the culprit. And no your wife or girlfreind is not involved
Old Jan 17, 2006 | 08:44 PM
Yankee7985's Avatar
Try checking your ball joints. OEM ball joints are not greasable and have a short life expectancy.
Old Jan 17, 2006 | 10:14 PM
mudd1's Avatar
Question
This wouldn't cause squeaks when the suspension is moving up and down gently over bumps would it?
Old Jan 18, 2006 | 05:28 AM
98Lariet4x4's Avatar
Yes. Yes it would, as I've has to live with that squeak for a few weeks now b/c I haven't had time to change it. One other thing you can try...May or may not work, but worth a shot. Climb under thr front and WD-40 every linkage. I've heard that sometimes a tie rod coulf be squeaking, and WD-40 does the trick.
Old Jan 18, 2006 | 06:35 AM
mudd1's Avatar
Will do !!!
What about the rubber bushings on the A arms? how do you lube them ? I assume wd-40 would not be good for them..
Old Jan 19, 2006 | 09:27 AM
mudd1's Avatar
ttt
