weird clunk when turning
I have 99 f150 5.4 when i am going around corners at a slow speed i get a werid clunk from the rear of the truck. only happens when turning but still checked my u bolts and drive shaft everythings tight. Just needed some other ideas what it might be thanks
Bear630 |
mine did that too. sounds like it's from the rear, but it actually turned out to be the CV joint and the rack&pinion. If it makes noise in a turn it's NOT the back :) *usually!*
Bear -
Check your spare and give it an extra click with that tensioning gizmo - that was my rear clunk! |
thanks for the replies not the spare thats in the bed gibson exhaust was a bit to big for the spare to say, had the cv looked at about 2 months ago and this was happening before i am going to keep looking thanks for the ideas please keep them comming thanks bear
I had the same clunk too. Sounded like it was from the rear. Turned out to be my sway bar links up front. I replaced the both, problem gone!
