Spindles?
Hey Guys,
I was wodering if someone could explain what exactly the spindles are. I dont drive a ford, but i have seen questions posted several times. I was just curious what exactly it it?
Jason E. Duke
Class of 2002 WHOOP!!
Texas A&M University
dodge4x4@ev1.net
http://www.geocities.com/agdodge4x4/index.htm
1996 Dodge Ram 1500 4x4
SLT Ext. Cab, Driftwood
5.9L 360CID V8
3.55 gears
265/75/R16
Jason E. Duke
dodge4x4@ev1.net
5.9L 360CID V8
3.55 gears
265/75/R16
You have a solid axle so they don't pertain to you. With an "A" arm suspension you have what is a spindle that is what the wheel hub is attached to and that connects to the upper and lower "A" arm. With a lifting or lowering spindle the wheel is raised or lowered and the "A" arms stay at their factory location. I hope this help to clear it up for you
Here is a picture of a lifted spindle
The one on the left is factory and the right is the lift.
GOLD RUSH
'99 F150 XLT SC SB 4x2 Harvest Gold
Factory[*]5.4[*]3.55 limited slip[*]Trailer towing package[*]In-dash CD player
Aftermarket[*]Ford Beanie bear[*]Slip on extender mirrors[*]Powerstop brake controller[*]Covermaster C1000 topper with wing[*]BugflectorII[*]Ventvisors (front&rear)[*]3 www.f150online.com decals[*]Ford Lumi Logo[*]Steelhorse Billet grill[*]Ford hitch cover[*]Yellow wire loom[*]Hyper White head light bulb[*]Fender badge on tailgate[*]Painted to match AVS slotted taillight covers[*]Ford system 4 alarm[*]Clear turn signals[*]"Blazer" strip reflectors under tailgate[*]FORD script antenna painted to match[*]Cup Holder courtesy lights[*]IonOptics driving lights as reverse lights[*]12 Volt power outlet in bed[*]Power port/Cigarette lighter courtesy light[*]4 Driving lights in grill[*]Next who knows???
<A HREF="http://www.firezap.url4life.com" TARGET=_blank>
</A>
<A HREF="http://njf150truckclub.homestead.com" TARGET=_blank>
</A>
firezap@f150fanatic.com
firezapper@home.com
[This message has been edited by Firezap (edited 11-03-2000).]
GOLD RUSH
firezapper@home.com
Yes,
that does clear it up. Thanks for the info. So thats how they do the lift on the f-150. What if you want a 5" lift, do they just keep putting spindles on that are made 5" from the originals?
Jason E. Duke
dodge4x4@ev1.net
5.9L 360CID V8
3.55 gears
265/75/R16
Jason E. Duke
dodge4x4@ev1.net
5.9L 360CID V8
3.55 gears
265/75/R16
Dodge4x4-
Well you don't drive a Ford, but at least you're an Aggie. '97 whoop!
'98 F150 S/C 5.4 V8 4x2, Aggie maroon, spindle lift, blocks and leafs, Rancho RSX shocks, Airaid filter system, Pro Comp 305/70/16, AR Baja 16x8, Dynomax duals, and some other stuff
It would be more economic and safer just to do a combo of suspension/body lift for the five+ inches. Plus the spindles have to support the truck and fit in the factory assembly for it all to work well, and I don't think anything above 3" will do the job.
A - A - A - WHOOP!
'97 F150 w/ devastating 4.2L power: CAN spin tires on wet grass!!!
mods:
-awesome skull head shifter ****
'nuff said
A - A - A - WHOOP!
mods:
'nuff said
