Urethane Swaw bar bushings and noisy pump
I am wanting to order some urethane sway bar bushings for my 03 2wd. The energy suspension kit says it's for the 29mm sway bar. I measured my sway bar with a set of calipers and came up with 1.21" or 30.734 mm. I need to know if the sway bar was changed between 01 and 03. I kind of doubt it would change, but I'm also unsure of ordering the 29mm kit. Can someone with a 2001 2wd F-150 please measure their front sway bar with calipers? Or someone with an 03 using the 4.5147 kit measure your sway bar? Maybe I need the Expy set for the 32mm bar?
My other question is about the power steering pump. This thing is sooo loud. I hear the pump over the exhaust and everything else. It seems to work fine, but it's darn annoying. Any thoughts? I'm thinking of asking the dealer to replace it. Thanks, Mitch |
