Auto Lock
Ok Dakota,
I tried to scan this page but, I have a piece of $h!# scanner. I am assuming you do not have an owners manual, if you do, don't tell me.
Ed
Deactivating/Activating the autolock feature.
BEFORE following the procedure, make sure the ignition is OFF and all vehicle doors are closed.
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key ON
2. Press the power door UNLOCK control 3 times.
3. Turn the key from on to OFF.
4. Press the power door UNLOCK control 3 times
5. Turn the key back ON. The horn will chirp.
6. Press the UNLOCK control, then press the LOCK control. The horn will chirp once if autolock was deactivated or twice (one short, one long) if autolock was activated.
7. Turn the key off. the horn will chirp once to confirm the procedure is complete.
PS: I wish I could type with more than 2 fingers.
Ed
