SuperCrew
Linkage problem???
Old Jul 21, 2000 | 09:41 AM
Gator13's Avatar
Angry Linkage problem???
Has anyone had a problem with the transmission linkage on their SC?? When I shift into drive the truck is still in neutral, I have to shift down into 2nd then back to Drive before the transmission engages? has anyone experienced anything similar? any ideas???
2001 F150 SuperCrew 4x4 XLT, 4.6L, Black, Front Captains Chairs, Medium Graphite cloth, 60/40 bench, 17" 10-spoke wheels, power seat, cab steps, sliding window, tow package, remote key entry, CD changer, Moonroof
Old Jul 21, 2000 | 11:24 AM
Truckdog's Avatar
Post
Definitely not a problem with my SC.
'01 Lariat Supercrew Oxford white, 4X4, 5.4 V8, limited slip, skid plates, tow package, captains chairs, Line-X, Super-Whites bulbs, westin Nerf bars.
Old Jul 21, 2000 | 05:00 PM
1stnuford's Avatar
Arrow
HAVEN'T HAD THAT PROBLEM OR HEARD OF IT. THE ONLY THINGS SO FAR ARE; A/C COMP MAKES A TICKING NOISE AND THE DAMN TRUCK WANDERS ALL OVER THE ROAD. FORD HAS ALIGNED THE FRONT AND IT HELPED SOME, BUT NOT TO MY LIKING. HEARD THAT THE TIRES MAY BE DOING IT.I'VE PLAYED WITH AIR PRESSURE BUT NO HELP. YOU NEED TO VISIT YOUR DEALER ON THE LINKAGE. THAT'S WAY OUT OF LINE !!
2001 SCREW 4X4;OX WHITE/SILVER;5.4L;SUPERCHIP;AND NO DECALS OR PINSTRIPING!
Old Jul 25, 2000 | 12:05 AM
jeb's Avatar
jeb
Post
I did not have your identical problem with the transmission on my Supercrew but I did have a problem. When I shifted from reverse into drive the motor would shut off. This only happened three times all on the same day, but it triggered a service engine soon light that would not go out. The service manager said the error codes pointed towards the transmission and they thought the torque converter was locking up. They ended up replacing what I think they called the "hydrolic valve body". I am not a mechanic so don't flame me if my understanding of the service mangager's explanation does not make sense. But, I do know if you are having problems with the drive train it doesn't surprise me. I have had the entire rear axle assembly replaced and this part of the transmission replaced (all before I put 1000 miles on the truck). All the info about the axle can be found in the "noisy brakes" postings.
