F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   SuperCrew (https://www.f150online.com/forums/supercrew-63/)
-   -   truck won't go into gear (https://www.f150online.com/forums/supercrew/259641-truck-wont-go-into-gear.html)
bross Nov 4, 2006 06:12 PM
My F150 will not go into gear while it is turned on. It will go into gear if you turn the key half way and then put in neutral and then start it. Also at the same time this happened the power windows, wipers and the buzzer for the door doesn't work. All the fuses are good.
ws6_guyscrew Nov 6, 2006 03:12 PM
hmm.... fuse maybe?
SSCULLY Nov 6, 2006 05:41 PM
Either include the truck info with the post, or complete your profile.
Need MY.
If you need to turn the truck to the run postion, and plut the gear shift level to neutral to start it, and get it into gear, the shift interlock is not working.
First question, are you having problems with your brake lights also ?
Some MY the interlock is part of the brakes, others it is seperate ( that is why I asked for the MY ).
