What can my SuperCrew tow?
Ford's 4,6-liter Triton V-8 (rated at 220 hp at 4,500 rpm and 290 lb-ft of torque at 3,250 rpm) and its 5.4L Triton V-8 (260 hp at 4,500 rpm and 350 lb-ft at 2,500 rpm) are available, backed by the 4R70W four-speed automatic with overdrive. With the right powertrain equipment, the SuperCrew can be rated to tow as much as 8,000 pounds (2WD) and 7,700-pounds (4WD).
I pull a Travel trailer that is about 6800lbs. I have the same setup as you except I have a 2003 4x4. It does a great job towing. The truck has a max combined weight (trailer &truck) of 12500 that you are not supposed to exceed. I am right at that and it tows pretty good, Kinda wish I had an F250 for those windy days, If you are planning on towing more than a few hours drive, I would probably either get a lighter trailer than mine, or a slightly bigger truck.
