Which pump flow coolant ?.
Hi all, I've been trying to figure out which pump flow coolant pumps have our truck oem 2007 5.4L 3V, but I have not gotten anything. Anyone have any idea exactly pumped flow? And if there is a pump motor that drives these higher coolant flow. I read somewhere that the 2005 Navigator drive more flow but I'm not sure of that and if they fit in our engines. I read that Meziere pumps produce higher flow but life is short and where I live I can not afford to have a short shelf life. Thank you.
Tarajearme, you will excuse my incompetence but I've been looking in the bilge pumps Jabsco page looking for an application to drive the engine coolant in my truck but can not get a specific application. I've seen you in other post has recommended this brand but I get nothing. I firmly believe that my oem pump is not enough for the conditions where I live, but I have much fear of using an electric pump and that this failure., But do not get a high flow mechanical pump for engines nustros. Thanks and sorry.
Ok, but these are pumps for the intercooler, I'm talking about water or engine coolant, no intercooler, so I could not get the specific application. Meziere pumps do not give me confidence about the possibility of a failure, so I think I should go to a higher flow mechanical pump in another post talking about a bomb Timskelton Navigator 2005, but not if they fit in our engine 5.4 L 3V and the pulley ribs supercharger 6. Here is my problem, and I change my OEM pump that is leaking.
I have the Meziere as well, probably ~16,000 miles no problems.
http://www.summitracing.com/parts/me...view/make/ford
