Small update
Small update
So I got bored and finally put a little money into the truck. I added some fresh HT0 plugs (gapped .032), some granatelli solid coil wires, a larger idler pulley and 3" blower pulley.
My brisk plugs were starting to missfire at idle (perfect at throttle) so I figured I would change them along with the stock coil spring cables in the ignition coils. Stock springs average 5 Ohms resistance while the Granatelli soild wires have .5 ohms on average according to my DVOM. Granatelli says they should be .05 ohms but I've never heard of anyone actually having theirs read that little.
I also installed a 3" Whipple pulley which replaced my 3.125". 3.125 is suppose to be 10 PSI while the 3" is suppose to be 11 PSI. I never saw more then 9.5 with the 3.125 and haven't ran the truck long enough to see if I get 10.5 now on the boost guage. I did only get into it once at 30MPH, truck downshifted and spun the tires fairly good. The wideband showed 12.5 to 13.5 A/F so I shut down fairly quick. When I got home I added another 2.0 richer with the SCT handheld so hopefully it will be be around 11-11.5 WOT. I'm still on my VMP 3.125" tune.
Oh and after I installed the 3" pulley I maxed out the slider tensioner so I had napa find me a bigger idler pulley that goes after the whipple. The ones whipple provide are 1 3/4" about and napa found me a 2 1/4" pulley that worked perfect. So far no belt slip but limited WOT. I'm hoping to get a dyno run in sometime this winter as I've had a few minor upgrades since my last dyno pull whenever the hell that was.
Cool. Looking forward to the results. Btw the 2.0 adjust for the a/f on the SCT should take you from 12.5 to 12.3. Thats how mine works anyway. My a/f is set at 11.2 in the tune and I have end user adjustments which allow me to lean it out 2.0, 4.0 and 6.0. 11.2 plus the 2.0 takes me to 11.4.
Interestingly the best track times and highest torque on the dyno have been on the 11.2 setting. The long stroke 5.4 loves the fuel. However the highest hp readings came at 12.0. But as I leaned her out a step at a time at the track working my way to 12.0 a/f she got slower and slower.
Gezze sorry I didn't see this thread earlier.
Am gonna locate my IAT to a different position. Over the runner it heats right up when the engine is shut down. Also might have clearance issues with an 'L' Inlet elbow.
And why 5/50w? Iam happy with the Moby 1 5/20 sync
It is a 3v and after 1000 miles the vct system is just as happy as any other weight oil I've ran. Also the 2013+ mustang 5.0s oil cap says 5w-50 with their vct setup.
I switched due to the fact that a blower dilutes the oil faster due to blowby and the extra pressure created by the boost pushes on crank bearings harder pushing out thinner oils. 5-20 is for fuel economy, 5-30 to 5-50 is for wear protection. Ive seen ford engineers say they recommend 30 weight but ford picked 20 for fuel numbers.
Im calling my dyno guy today to setup a time
I am glad to see that someone other than me realizes the value of heavier viscosity oil in a forced air inducted vehicle. Several years ago I brought this up and stated that I was running heavier oils in my FA vehicles and people looked at me like I was insane.
I totally agree with this practice.
