Supercharge a 07 F150 5.4L 3V
I have a 2007 5.4L with 89k miles. I also have true full dual 2.5" flowmaster exhaust. I want a whipple supercharger. I read in another thread that I should change the injectors to 36 lb cobra injectors and get a troyer valve body but I called whipple and they said I don't have to change anything at all. This is my daily driver. I have no intentions of going over 8 psi. What are yalls opinions?
Don"t listen to Whipple on this one. I don't know if anyone runs the stock injectors with the Whipple even at stock boost levels. On mine I tried to see what it would do and at colder temps. mine would go lean at anything past 1/2 throttle so I upgraded to the 39# injectors and a new tune. Valvebody is a good idea.
Tim
Tim
Just figure on getting a SCT XCAL tuner with an email tune from Troyer or JDM with 39# injectors and a valvebody to get you started unless you are close enough to a good place to get a dyno tune. It seems there are only a few people around the country that have a good reputation with tuning these trucks with a supercharger. The stock tune that comes with the Whipple is not very good and there is nothing you can do with the programmer they provide for the increased injectors and the valvebody.
Mine is my daily driver so NO, its not to much for a daily driver, if anything you will want more. I thought the same thing about 8 psi being enough but I wish I had more. You probably won't see 8 PSI anyways, most people don't. I only can see 8+ when its winter time, in the summer for me its best is 7.5 but its not as hot up here compared to most of the guys running the Whipple.
Tim
Tim
You'll love the Whipple. Hell you'll love any blower. 8psi with a custom tune will land you right around 390-400rwhp. You will need the 39lb injectors. (I've got a set if your interested). The tuning that comes with any supercharger is horrible so go custom with SCT and a Troyer or JDM tune.
