How to: Ford Lightning swap on a N/A F150
#31
I appreciate all the help and guidance you have given me str8t! and thanks to all the others that have helped make this swap so much easier! Big thanks to tarajerame, phil, twinskrewed, and many others! Also thanks to all the good people on lightningrodder!
#32
#33
I got the info from LR in the how to gen 2 section. I found two or three of them in the back pages. I am going to do the one where you take out the freeze plugs and run some Lincoln navigator parts and connect the lines. I'll see if I can dig them up.
#34
http://www.lightningrodder.com/forum...ead.php?t=9460
This is the coolant cross over that I am going to do.
#35
thanks, i read it on Lrodder, i didnt use the AN fittings that some of those guys were, i used brass fittings. if you look on the thread it has what size parts you need. i wouldnt do this mod again tho, i had problems with the fittings leaking, so i had to resort to JB welding them.
but if i was building a motor to put in, i would do what formuladriver is doing and use the navigator parts.
#36
#37
#39
, We know how to keep them clean... Many don't and let all that crap feed into the engine compartment.
What usually happens is the wheel well skirts fall off at some point. The driver is unaware. Or , a body lift is installed without lengthening the skirts.
Engine gets hit, so do the coils... - Plug wells can fill with water, etc, etc...
____________________________________
str8t six - Good write up, but you suck at video's . I would like to see a few good launches from the outside. - Like Joey did, -
http://s131.photobucket.com/albums/p...%3Dlaunch3.mp4
Fun project, - you still data logging? Have the final tune yet? - I didn't see the whole thread, might have missed it.
#40
dont be knockin my videos, it was cold outside!! i didnt want to stay out there.
this one isnt very good
http://www.youtube.com/watch?v=DDzQg...eature=related
heres one on the inside.
http://www.youtube.com/watch?v=UT74z...6fAUAAAAAAAGAA
The following users liked this post:
#41
Installed the battery, fired her up, lost one coil right away and the rest were shorting intermittently. That was back in 2000. I think I learned a little since then ? Very little..
#42
Today, people use Teflon tape on all threads, however, new threads just cut the tape as you put the two parts together, and don't improve the sealing quality of the tapered pipe thread.
So, the trick, -well not really a trick, use a silicon made for high temp sealing, that can handle a little pressure. High Heat Ultra Black (Permatex) will seal them up. Smear a little on the threads before matting together.
#43
#45
There are a lot of good buys out there so I would think you could beat the $3000 mark.
Here is a reasonable deal, but not complete. This is how I started and easy to finish this off. Just providing as an example:
http://www.lightningrodder.com/forum...ad.php?t=92264
