procharger 8 rib belt???
#31
i guess I'll try to run a larger diameter lighting 8 rib crank pulley with a 6 rib belt (17psi pullied) and add an extra idler at the top, then install an external waste gate set at 14 psi before the innercooler to make 12psi into the engine about 3400rpms and hten it'll pull harder down low and still maintain the top end charge
http://www.compressedairstore.com/Mo...p_99-3153.html
#32
Im in the process of switching to a blowthru and venting to atmosphere.I just got Justin's maf upgrade:
http://www.vmptuning.com/store/index...=208&parent=29
Im putting the maf just before the t/body.
Once you go blothru,an adjustable wastegate coupled w/ a higher boost pulley sounds interesting.Complicated,but interesting.
#33
Actually I am using a boost limiter with a 90MM lightning mass air, I am returning the air back to the intake elbow near the bypass valve return location. I have had this system on for over a month now and it has worked perfectly, No problems with air/fuel ratios or check engine light. I am very happy with the set-up!!!
#34
#35
Originally Posted by ganiman
Only way to do that is converting to a blow thru maf.Like ONELOWF sed,all measured air needs to go into the engine,otherwise your tune is useless.
[IMG][/IMG]
#37
the blow thru is the best way to run and it allows for the hiss when you let off since you get to vent into the atmosphere instead of running a bypass hose
The boost controller is set for 10 psi, and it's hard to get used to when it opens at high rpms.
#38
My change over to blow through is in the works too.
Maintenence sucks!
#39
this is what I was also considering doing:
http://www.musclemustangfastfords.co.../photo_06.html
would mke the procharger *edit* or any other centrufigal*edit* a better tool for the guys who tow a lot plus make it better for the street driven trucks (it would cost a bit of peak power but the low end is increased) and swapping to a blow thru MAF would be the only way to make this run easier
#41
I used this one: http://cgi.ebay.com/ebaymotors/GODSP...em180215099898
The angled inlets were no help to me, and I cut them off straight, and then used rubber elbows to head toward the engine. The challenge is getting over the sway bar.
The 4 x 12 x 18 cools well. I am seeing temp rises of about 30*, during wot runs.
#42
Originally Posted by ONELOWF
I think it's too wide if you want it to fit between the frame rails behind the bumper - 27" available?
