lookie what I got
the big brown truck showed up yesterday and dropped this off:
https://www.f150online.com/galleries...698-197122.jpg https://www.f150online.com/galleries...698-197116.jpg https://www.f150online.com/galleries...698-197117.jpg |
now all i need is crank pulley (unless I can use the original crank pulley left over from when I stuck on the MAC 3 piece underdrive pulleys)
39# injectors and 90mm MAF to match the 255lph fuel pump and it'll be ready for a tune |
:drool: I WANT ONE!!! good luck getting it in have fun :rocker:
Nice, have fun with it!
Sweet.
Here are some suggestions based on my experience, since it's all apart anyways: - Change the oil in the supercharger. Make sure you don't turn the blower upside-down after you do. - Replace the bearings in the pullies. Don't get them from Procharger, they'll charge you like $50 for a pully/bearing assembly. Just remove the pullies, the bearing slide right out. Take the bearings to a bearing supply shop, get the best high-temp/high-speed bearings they have (likely NSK). Get some spares while you're at it, because they're a wear item and will fail from time to time. - Contact Mike Dunn (madferraristi on this site, or http://www.madenterprise.com/F150.htm) and talk to him about his special bolt kit. For some installations, the bolts that attach the mounting plate to the engine are crappy (mine rubbed the belt...Mad's bolts fix this). - Get some washers so you can shim the pullies after you mount everything. The pullies rarely are in perfect alignment with the belt/crank pulley. If I can think of anything else, I'll post up. :thumbsup: |
I need a crank pulley before it's ready to go on, thanks Jordan not mike I will look into the bolt kit from Mike
Looks like fun - enjoy!
You may want to look at the Motoblue interchangable lower pulleys ( rpmoutletdotcom?). I'm not sure that it will align with yours, but it bolts onto a stock 5.4 HB. https://www.f150online.com/galleries...389-163475.jpg |
https://www.f150online.com/galleries...698-197122.jpg https://www.f150online.com/galleries...698-197116.jpg https://www.f150online.com/galleries...698-197117.jpg Guess I need to becareful who I challenge in town now :) Awesome, would love to see it when it's done. |
You may want to look at the Motoblue interchangable lower pulleys ( rpmoutletdotcom?). I'm not sure that it will align with yours, but it bolts onto a stock 5.4 HB. https://www.f150online.com/galleries...389-163475.jpg I need a crank pulley anyway thanks for the advice I'll look them up |
got this delivered today:
https://www.f150online.com/galleries...698-198452.jpg https://www.f150online.com/galleries...698-198454.jpg now I am complete enough to install it: but I think injectors, 90mm MAF and a 255lph fuel pump and a dyno waiting before i install anything |
BOOST what a wonderful feeling :thumbsup:
i wish that brown truck would make me a delivery like that! good luck!
did you get a chance to run it yet and test it out?
