05 F150 Whipple SC Instructions
Old 06-27-2007, 02:34 AM
khendrix2374's Avatar
I'm thinking of removing all my HT0 plugs and re-gapping them tighter.
I never put one ounce of thought to gapping the HT0 plugs before I installed them. Now, I'm kinda of regretting it.
I got My HT0 plugs off Ebay for $75
Old 06-27-2007, 09:20 PM
goody029's Avatar
Originally Posted by wstafford
I did it over a couple of days. I would work until I got tired and frustrated then take a break. My back was the worst of it as I had no one to help set the blower. Not to bad though, just take your time.
BTW I'm thinking about the dynatechs. What is giving you problems?
The hardest part was getting the exhaust manifold bolts and studs out. You also have to remove the cross member and the starter just to gain access. Having said all that, they sound awesome!!!!!!!!!!!!!
Old 06-27-2007, 11:08 PM
wstafford's Avatar
Is there any way that you can get a copy of the instructions to me? I have a toll free if you can fax them. I'd like to take a look before I take the plunge
Old 07-03-2007, 08:15 PM
MeanGene's Avatar
Thanks for the quick reply. Fax number is 585-321-1659.
I see your running 10lbs of boost. Have you done any work to your lower end???
The recieved fax is usually in a tif format which is digital. If you can could you send those tif files to the email address I will PM you with?
Old 07-10-2007, 01:30 AM
weazel's Avatar
Registered User
what throttle body does whipple use?
hey does the whipple use the stock throttle body and would larger after market one fit on it?
Old 07-10-2007, 01:51 AM
cdnance's Avatar
this is somewhat of a different subject, but kinda the same... i have an 05 with almost 100k on the motor, but want to do something like add a whipple. it the milage and wear going to cause a problem?
Old 08-05-2007, 11:11 AM
JOHNNY BRAVO's Avatar
whipple
this is actually for WSTAFFORD. I've been installing the whipple and i'm stuck at part of the brake booster. I have the 04 fx4 and i only see the 1 line comming out of the master brake cylinder and not that tee that whipple is showing in the manual...also where is the line that whipple is showing thats running on top of the firewall..... the insrtuctions are good but they were deffinitly better when i got them printed out in color.... for the price whipple should send out a video..... please feel free to email me fox540@aol.com do happen to have a pic of the brake booster setup that you did just so i don't screw something up..... thanks agian
Old 08-05-2007, 09:09 PM
wstafford's Avatar
Email on the way!
Old 08-05-2007, 09:19 PM
MeanGene's Avatar
Boy, do I need to have a look at those Whipple instructions. What in the world does the brake booster have to do with an SC install?
Old 08-07-2007, 06:10 PM
nofear6372's Avatar
Helping Johnny Bravo
I am helping Johnny Bravo with his supercharger and we are lost regarding the PCV hose and fitting on the driver side valve cover. We took off the old hose like the directions said but then it never says to hook anything back up to the driver side head barb nipple. Are we supposed to hook something up to that again and we also have a spare hose that we have not used. Please help if anyone can.
Old 08-07-2007, 06:11 PM
nofear6372's Avatar
Mean if you haven't seen the instructions you are in for a treat....that was almost one of the most confusing things that brake booster.
Old 08-09-2007, 12:45 AM
MeanGene's Avatar
Elaborate..
Old 07-22-2017, 08:44 AM
City of Champs's Avatar
I am currently searching for a copy of the 2005 Whipple install guide and parts list. I can't find anything online, can someone help me out?
THANKS!
jordonstandeven@hotmail.com
Old 12-28-2017, 01:28 PM
tn50stang's Avatar
Wipple supercharger instructions
I am also looking to see if I can get a copy of the instructions for my 2005 F150. Thanks Tom
Old 01-15-2018, 03:02 AM
The following users liked this post:
Quick Reply: 05 F150 Whipple SC Instructions
