How do I remove rear speaker 05 super cab?
I have 05 Lariat .Super cab. I need to replace the rear speaker in the rear door. I have done searches but I keep coming up with speaker removal on crew cabs. Different panel. All imput greatly appreciated. Thanks. Bob.
You have to remove the door panel to get at the speaker.Pull of the plastic pillers on the top of the panel,remove the 2 bolts,pop the cover with the window switches theres a bolt in there,2 bolts behind the cover on the door handle and 2bolts on the bottom of the door panel.Then lift it straight up.
