J l 10's
Ok I posted this in another froum must have been up too late. Anyway has anyone had the oppertunity to run a pair of 10"w0v2 Vs The 10"w1v2 in the spec portion of the web site it says the
10 w1v2 the one way liear excursion is .375 with a mounting depth of 4.34 10w0v2 the one way linear excursion is .45 and the depth is 4.90. I am thinking the depth is lager on this one because of the magnet? rec for sealed box is .65 The box I have will house either one I currently have the 10w1v2. On paper is the 10w0v2 going to give me more noticable bass or should it be so minimal just keep the ones I have. Nothing wrong with the ones I have, they work great. but, depending on the feedback, if it is posative. I may try a pair of the 10w0v2 |
Originally Posted by hlbbig69
(Post 3943411)
10 w1v2 the one way liear excursion is .375 with a mounting depth of 4.34 10w0v2 the one way linear excursion is .45 and the depth is 4.90. I am thinking the depth is lager on this one because of the magnet? rec for sealed box is .65 The box I have will house either one I currently have the 10w1v2. On paper is the 10w0v2 going to give me more noticable bass or should it be so minimal just keep the ones I have. Nothing wrong with the ones I have, they work great. but, depending on the feedback, if it is posative. I may try a pair of the 10w0v2 But no, I do not think the difference would be worth the money. Try to listen to some if you get a chance. |
Originally Posted by mSaLL150
(Post 3943458)
I dont think it is worth the money, they are pretty similar in output. I switched from the W1 to my Kodas which was more dramatic difference. The w1 has 9mm of throw while the Kodas have XBL^2 motor and 20mm of throw. Much cleaner and certainly louder if I want it to be.
paging mSall150
(Post 3944656)
The Kodas that you refer to are they for a small box application and how much power do they require. I have never heard of that brand before is there a web site I can go to and see the specs for the Kodas.
There is a JL Audio w0 10 inch for sale in a box for $30. Is that a good deal/ good sub?
D |
Originally Posted by D's984x4
(Post 3953013)
D Sone of IncriminatorAudio's Flatline models will work well in small sealed applications. Sundown Audio's E8 drivers will also sound fantastic, and you could probably fit 2-4 depending on your space and budget. |
(Post 3953013)
D HLB |
| All times are GMT -4. The time now is 05:01 AM. |
