Pics of my custom subbox
What size sub are you using?
Is your box sealed or ported? Could you post the measurements of your box? |
10" Dual Voice coil 4ohm powerbass usa PBX 10vd2
250watt RMS 5.75" mounting depth sealed I figure my empty volume is .76 and about .67 with the sub. I am making a new box. This one has some issue, especially with the big sub and small volume. I heard my buddies brand new box in a new tacoma 4 8" kickers with 400watt kicker sub. It was tight and load not much boom but much louder and cleaner then anything my sub would do. I started playing with my box and noticed the sub was actually hitting the floor and extreme bass. I have about 3/8" off the floor. the miter joints are clean cuts but still not air tight. I need to make the angles different. I routed the sides and they are tight. I assembled the whole box during test it could stay completely together with no glue or nails. I still think the volume is too small or maybe my amp is blown? and the 1/2" vibrates too. I have 3/4" MDF. I am going to make a simple rectangular box with all routed pressed fit square joints. It wil be tight and probably 1.2cuft. If that works I know it is a volume thing. I will then build a cleaner fit box. All of the off the shelf units are only 0.65-0.70 cu ft for a similiar setup and they have no vilume and only sound good at 58-70hz |
