Kicker CompVR 10's & ZR 240
Old Jan 7, 2004 | 10:03 AM
b_bruton77's Avatar
Question Kicker CompVR 10's & ZR 240
I just installed two Kicker CompVR 10's 4 ohm and a ZR 240 with the XMS Chip in my F150 Ext. Cab with a down firing box. My question is I have the VR's wired parallel and I am bridging my amp as well. Is this a good idea or should I not bridge my amp? Also on my radio it has a low pass filter, 80 or 120 are the selections, what should I set it on, and what is the difference? Thanks for all your help.
Old Jan 7, 2004 | 01:55 PM
rICEr's Avatar
subs in your truck
it all depens on the specs of your amp. your subs will be wired in parallel, depending if you wired them right, and if your amp can handle a 2 ohm load. if you have wired them right and your amp can handle the load then you are alright on that end. you will have to adjust your gains accordingly and as far as your deck options they will also have to ba adjusted to what kind of music you listen to and the volume that you listen to it at. the adjusting is done best with all things turned down, adjust the volume to a decent level, usually one of the loudest that you lesten to it at, and then adjust your gains and settings on your amp and your deck.
