Can you say TRACTION ACTION ???
Old May 10, 2002 | 05:54 PM
SVT_KY's Avatar
Talking Can you say TRACTION ACTION ???
Well, I am TIRED of SPINNING ...
So my neighbor and I were talking and I mentioned
spring clamps and he says, "We got something at work that
might work REAL well for that" Support braces from a
300 ton crane ... LOL
Whatta THINK ???
Old May 10, 2002 | 05:56 PM
rfat16's Avatar
I made my own and put them on and don't really notice the difference. If you know of a good spot to mount them let me know cause i put mine on the last 2 springs and i don't really notice much.
Old May 10, 2002 | 09:52 PM
SVT_KY's Avatar
Talking
Will do Rfat ... I prolly need some advice muhself...
Old May 10, 2002 | 10:50 PM
Lightning Boy's Avatar
See if you can get in contact with 1BADTK... He would be able to help you here...
Old May 11, 2002 | 12:04 PM
usahooters's Avatar
They look like they will work great. Use some strong grade 8 bolts to mount them and in my opinion they need to go on the front side of the axle and only over two leafs near the front of the spring. I use them and also removed my front sway bar to help with weight transfer. I only stall up to about 900 rpm's so not to take action out of the truck and when the light drops its to the floor quick, the truck transfers good and the spring clamps help with axle wrap by makeing the two leafs work together and keep them stiff. I get 1.78 - 1.80 60's everytime on F1's @ 28psi. I treid them in many places and even used two sets on each side then ended up with the single set mounted as descibed. good luck
http://www.supercrewdriver.com/galle...6865&anum=1351
Old May 11, 2002 | 07:52 PM
SVT_KY's Avatar
Thanks USAHOOTERS ... I think I will try that location
next week ...
Old May 11, 2002 | 10:18 PM
usahooters's Avatar
Anytime SVT_KY just play with them some until you like it. Take you ratchet to the track and move them around. When I ran two sets on each side it seemed a little to stiff for me with everyday driving.
Old May 12, 2002 | 10:19 PM
Crazyone's Avatar
where is my set cliff? =)..
<--- Always the mooch
Btw them sure are some nice towels under there, you sell them?? <grin>
Brandon
Old May 13, 2002 | 12:27 PM
MotorcycleMan's Avatar
Brandon
I have a lot of those. Call me and I can hook you up.
245-2512 after 4pm anytime.
Harold
Old May 13, 2002 | 01:54 PM
rfat16's Avatar
So in the front part of the leaf spring????? Anyone else have these on and tryed them multiple ways????
