Attn people in the salt states...Save your Fender!
Old Aug 9, 2003 | 09:40 AM
inski21's Avatar
here is a design flaw I have found, after it was too late.
The inside rear fender liners on our trucks is metal, at the very middle, and traps salt and sand inbetween the exterior skin and inside liner. It sits there and eats away from the inside out. This is a veiw of the stagnant sand sitting in my fender
I have a solution if you want to save your rear fender exterior sheet metal...
Old Aug 9, 2003 | 09:46 AM
inski21's Avatar
this pic is looking from the right rear fender inside, looking out.
Drill holes here in the inside liner and flush out with water several times each winter. Make sure you paint any bare metal exposed from drilling.
Caution! The exterior metal is only 1/2 inch away, dont drill thru both
Old Aug 9, 2003 | 09:58 AM
inski21's Avatar
What do I do now?
-cut away fender flares?
-weld in new sheet metal?
-leave like that, its rugged lookin?
-bondo?
-build a wide body kit?
-duck tape?
Old Aug 9, 2003 | 12:15 PM
signmaster's Avatar
Inski,
Mine is going through the same. It hasn't popped through yet anywhere, but it's just a matter of time.
I looked, hoping to find some formed plastic edge guards similar to the new trucks but didn't find any. The only thing I found was flares.
Mine will be better left alone for now, but I don't see any easy and effective solution. I might just live with it to decide how long I'm keeping the truck, and at that point paint it. I also have some of the famous rocker panel rot under the extended cab.
If I do decide to keep it and paint it, I'm going to cut out the inside cover, and fill it with epoxy filler first.
Old Aug 9, 2003 | 12:33 PM
dave186's Avatar
get a repair panel. if thats too much work, try fiberglass.
Old Aug 9, 2003 | 12:57 PM
FORD302GUY's Avatar
Repair panels are a pain in the butt. I just put one on an 88 pickup that rusted exactly like yours. It took forever and still didn't look perfect when I got done. Next time I will get a whole bedside. They are more expensive, but worth it in my opinion.
Old Aug 9, 2003 | 04:36 PM
inski21's Avatar
Originally posted by signmaster
Inski,
Thats how this "hole" started. I was going to sand the "surface" rust and repaint it. Well, after 2 or 3 pokes with a small screw driver and 2 or 3 holes punctured thru, I realised it wasn't surface rust. It was from-the-inside-out rust, every bit of metal in this area was toast.
I think I'm going to bondo or fiberglass it and paint it, and maybe find some conservative flares to cover the bondo look.
I washed this truck once or twice a week in the winter to avoid this kind of mess
Old Aug 10, 2003 | 10:56 AM
PKRWUD's Avatar
Yeah, but think how sharp you looked driving around in such a clean truck!
Okay, I tried.
Take care,
~Chris
Old Aug 10, 2003 | 12:07 PM
inski21's Avatar
I did look sharp! After snow storms people will drive around for days and months with salty-gray vehicles. Not me, I am bright and shiny the day after every storm
Old Sep 14, 2003 | 06:16 PM
94F1504X4's Avatar
I have that same problem just need to figure out how to fix it.
