Power source for FWD selenoids
Old Mar 16, 2026 | 06:11 PM
Mark1998's Avatar
Replaced the GEM for a second time. Don't have power at either FWD vacuum solenoids. Have checked fuses. Research says ground returns to the GEM
Where does the power come from for the FWD solenoids?
-Mark..
Old Mar 20, 2026 | 06:12 PM
Mark1998's Avatar
Hot wired the FWD vacuum solenoid today and the FWD engaged. So the problem is definitely is no power to the solenoid.
Does anyone have a link to the 4x4 drive schematic?
-Mark
Old Mar 20, 2026 | 09:38 PM
Does this help?
https://www.f150online.com/forums/vi...diagnosis.html
Old Mar 21, 2026 | 03:54 PM
Mark1998's Avatar
GLC,
It has indirectly helped. Fuse 23 was not blown, but in reading its description, in the manual it connects to the RPO relay. I have located the relay block under the dash but now have to determine which relay of the 4 is being used by the FWD solenoid.
-Mark
Old Mar 21, 2026 | 04:06 PM
Mark1998's Avatar
glc,
It has helped indirectly. Fuse 23 was not blown, replaced it anyway, no change. In the owners manual it states fuse 23 connects to the RPO relay. I found the relay block the RPO is in. Now I have to figure out which of the 4 it is.
-Mark
Old Mar 21, 2026 | 05:35 PM
The owner's manual should have fuse and relay locations and identification.
https://www.fordpro.com/en-us/fleet-...ls-and-guides/
Old Mar 22, 2026 | 09:09 AM
Mark1998's Avatar
The RPO relay block is under the "oval" on top of the dash. I should be receiving new relays tommorrow.
-Mark
Old Mar 24, 2026 | 09:07 AM
Mark1998's Avatar
New relay fixed no power to the FWD solenoid.
-Mark
