2006 Keyless entry
Old 06-23-2019, 03:16 PM
Ryan Spangler's Avatar
2006 Keyless entry
Guy,
im having an issue with my 2006 f-150 with the keyless entry and door locks. Last night everything worked as it should , today the truck unlocked with the fob but will not lock. I tried the keyless and no power to it. I open the truck up and hit the switch and nothing, it will unlock by the switch and key fob. I’ve checked the fuse the manual says it it and it is good. Any help would be appreciated
thanks
Ryan
Old 06-23-2019, 08:01 PM
I moved your thread to 2004-2008 section
Is this the keypad entry built into the door handle?
Old 06-23-2019, 09:36 PM
Thank you. And yes keyless on the door.
Old 06-23-2019, 10:15 PM
do you have any other symptoms?
I believe the keypad entry goes straight to the BCM, You might have a wiring issue or a BCM failure.
Does they keypad still light up?
Quick Reply: 2006 Keyless entry
