Need Some Advice
Need Some Advice
2012 F150 Ecoboost. 90,000 miles. All maintenance has been performed at dealer per the spec.
Two days ago my Check Engine light came on. Took is to the local Autozone. Their diagnostic gave me code P0016. Came home and made an appointment with the dealer. Yesterday morning the Check Engine light was off and it has not come back on. I haven’t noticed any performance issue.
This morning I go to my appointment at the dealer. I tell them the light was on and gave them the code. The guy told me I should have made an appointment with the “heavy tech” as he will have to pull the engine. I mention the light is now off. Ask if that means anything. He tells me “that happens all the time.” He then tells me the first available appointment with the tech is July 29, almost 6 weeks from today.
Before I spend mega thousands, my first question is does this make any sense? My second question is if the check engine light doesn’t go back on, can I keep driving this thing. My third question is should I just trade this thing in on a new model. (Semi kidding)
Read this.
https://www.obd-codes.com/p0016
As that says, it could be a sensor. But, it also may be the timing chains need replacement using my wild guessing skills!
