engine pink after tune up
Hi there , after the change of the candle and their cables, I have a problem, when the engine is hot, it is too hot or too much pressure, the radiator has yielded, I made a trip 800 km with my F150 2008 4.2 pulling a trailer car hauler, with a hot tube, around 2000 kg, he pulls his tongue, he pink, ......... I suspect the cam sensor ..... I'm right
thanks for the answers
Sorry for translate
sorry but Google has translated, and probably badly done, in short, since we have replaced, spark plug and power cable, I have a problem with the will of the truck, I think it overheats, the radiator has even broken , and I hear hardware, play the piano, climb a hill, and revolution the engine. As with the old engine when it was bad timer, as it is a ford f150 2008 with a V6, 4.2 L, and that this engine has coils, is there a problem with the cam sensor?
https://www.obd-codes.com/p0053
https://www.obd-codes.com/p0420
https://www.obd-codes.com/p2195
Sounds like you let the o2 sensors go too long and you now have restricted catalytic converters.
