2018 26 to 36 gallon swap
I picked up a 36 gallon tank somewhat local to me from a guy on FB. Said he only ran a few tanks through it. Saved about 40% over buying a full new setup
swap is plug and play + reprogram
I was surprised how much taller the tank is in the fuel pump area too
Very glad to have the lift at work for this, as well as the fuel transfer tank/pump
I then reconfigured the truck using Forscan, still waiting for the DTE to relearn to my driving habits/fuel economy
What all did you have to move over from the old tank to new tank?
I wonder if this would be a "plug and play/reprogram" for my 2017 2.7 EcoBoost SuperCrew with 5.5' bed. I haven't seen a 2.7 Eco w/ 36 gallon tank on any dealer lots around my house. Would make for a very long-range hauler!
Mine came with pump and sending unit in it already, but those would be purchased separately if you bought new. As well as sealing Oring and locking ring on top.
Mine didn't come with the heat shield that runs on the side of the tank. So I modified my existing one to be reused.
It uses all factory pipes, factory tank straps, factory filler neck all that!
I'd be willing to bet yours is Plug and Play + program as well
Transfer Flow manufactures a 50-gallon replacement fuel tank system for 2009-14 and 2018-19 Ford F-150 Crew Cabs with 6 1/2 foot beds.
• 2009-14 Model Years: https://www.transferflow.com/shop/product/0800115555
• 2018-19 Model Years: https://www.transferflow.com/shop/product/0800116883
Save $200 when using coupon code F150TF when ordering online at www.transferflow.com!
