Plenum coolant bypass
I'm pulling my plenum and intake for new gaskets, injectors, FP regulator, etc., and discovered the pipe coming out of the top of the water pump is shot (the one with the nipples for water to flow through the plenum). I found one on RockAuto without the nipples, which is fine because I was thinking of bypassing those lines anyway. So... what should I do with the two plastic nipples on the back passenger side of the plenum? (They are part of a plastic "plug" that contains the PCV vac port).
I'm guessing just put vac caps over them?
EDIT:
On a related note, is the Fel-Pro MS95985 gasket (alternate/OEM number MS16230) the updated, 4mm thick one? I can't find any specifications on it, but it is supposed to be "from 1/15/98".
EDIT:
But, point taken.
Ok.
