2005 f150 fx4 5.4 limp mode
New member, Need help I bought a used 05 fx4 4x4 114,000 miles i have a issue with limp mode at idle, i am able to throttle up in park or neutral , but if its in reverse or drive little power i can get up to about 35-40 mph but it is not fun and i cant seem to get any codes out of computer. computer was reset before I bought it, It has new timing FOMOCO timing redone, with milling 340 hv oil pump, new ford vct solenoids, I hooked up to AUTEL 906 bt cant find and thing out of limits, no codes, no miss fires, replaced MAF sensor cleaned injectors, cleaned throttle body, new fuel filter, fuel pressure is about 38 psi, Oil is full , trans fluid full, the things i have found no power to fuse 23, 25, 35 , 36 and ignition switch has been messed with,
limp mode
Fuel driver module intact. Very little surface oxidation, I looked at pre and post catalytic pressures 3 to 17 psi and main vacuum which was steady and fell off fast 18 down to 7. Catayletic converters plugged and when I looked down drivers side half had melted, although passenger side doesn't look as bad it still looks like it's my problem.
