4.6l 97 f150 misses and backfire
Old 02-10-2019, 06:12 PM
Lordron's Avatar
Replaced fuel pump and filter ran fine patked it next day started it to see if battery was dead missing all over the place backfired in intake manifold touched a plug wire shocked the crap out me so replaced all the plug wores made it worse
Old 02-10-2019, 06:15 PM
Lordron's Avatar
Sorry
Haven't changed the plugs cause it was running rwal good not to mention it's been parked for 3 years
Old 02-10-2019, 07:51 PM
You have spark plug, wires, and/or coil issues. Make sure you have the firing order correct and you use dielectric grease in the wire boots at both ends.
Old 02-10-2019, 07:58 PM
Lordron's Avatar
Changed wires
When it first started missing o noticed the wires have ruined grooves into each other I tried to move it and it shocked the crap out me I knew they were bad so I changed them I'm guessing I have fouled plugs maybe and dirty sensor and a vacuum leak and a little old gas
Old 02-10-2019, 08:01 PM
Lordron's Avatar
Boots
Boots weren't wet or oily either came out real good for original plug wire 219 k miles fuel pump only part ever changed I know because my grandpa bought it in 97
Old 02-20-2019, 06:27 PM
bigbronc's Avatar
3 yr old fuel......
Old 02-20-2019, 06:37 PM
Lordron's Avatar
Fixed
Drained fuel put leaded 101 ran it. Smoothed it out
Quick Reply: 4.6l 97 f150 misses and backfire
