Auto Start-Stop
Old 12-12-2018, 11:46 PM
Tampa-Harley's Avatar
Question Auto Start-Stop
Anyone else leave the Auto Start-Stop on and notice after fill up that the system does not activate at a stop?
This is a 2018 with 5.0L
Old 12-13-2018, 12:30 AM
A long read, but this tells you what must happen before it will activate:
https://ford.oemdtc.com/GSB/G0000115.pdf
Note that you can disable it by putting a dummy plug in the trailer light socket. That way, if you do not like it, you don't have to hit the button every time you start the engine.
Old 12-13-2018, 09:44 AM
JackandJanet's Avatar
I believe it can also be disabled using FORScan, if you want to go that route.
- Jack
Old 12-15-2018, 03:55 AM
Thank you, did not answer question but I did not know that it requires seat belt to be latched. I will pay more attention to that Thanks again
Old 12-15-2018, 11:29 AM
Interesting observation.
Old 01-01-2019, 01:19 AM
Smile
The TSGB did not answer my question. So I called Ford and got my answer. The system needs to keep running after a fill up so the computer sensors can determine the fuel used to fill tank. ie: E-85 or regular. Understandable. I was told the page of the owners manual this information is on. Still have not opened the book. Thanks all
Old 01-06-2019, 06:45 AM
NASSTY's Avatar
Mine works without using the seat belt.
Quick Reply: Auto Start-Stop
