Oil dipstick reading for cold engine
Let my truck sit for days and decided to check my oil level and noticed the dipstick to be dry. I had done an oil change 1000 miles prior so I'm pretty sure there should be oil in there. Also there has been no signs of overheating. Is this normal? Or should the oil level be checked when the engine is warm?
No obvious signs of leakage since there's no trace of oil coming out of the gaskets or onto my garage floor. I had purchased the truck when it had about ~189k and now it has a little more than 190k on it. So about ~1000 miles of driving since I had the oil change done. I put in 7 qts of Mobil1 5w-30 and a Motorcraft Filter because everyone swears by it :-). If I'm burning oil what's one way to determine that?
If oil is disappearing and the engine isn't leaking, it's burning it, either from oil getting past the piston rings or being blown into the intake from too much blowby, or getting past the valve seals. How much is it burning? If it's a qt every thousand miles, I'd just keep it full and keep on trucking. If there is blue smoke coming out when it is first started, that is an indication of valve seal leakage.
i'll try and update this thread when the time comes for my next oil change and report the results (which may take a while since my truck is more of a weekend warrior than a daily driver). So far, it is running much smoother knowing there's enough motor oil & "snake oil" flowing through the internals....
