4r70w Trans swap from 04 Crown Vic to 02 F150
Old 08-19-2018, 02:15 PM
LowFlyin98GT's Avatar
Ok, so i've been battling this issue for awhile now and dont understand whats up. I put the 4r70w trans out of an 04 Crown Vic into my 02 2wd 4.6L F150. Everything I have read tells me they should be the same. All plugs are the same.When i plug in the speed sensor, the truck thinks its going 100mph when its really going 20. I swapped the sensors out, no change. Now, the speed sensor itself (i have the harness out of the crown vic too) has the same blue/yellow wire in the same place as the vic, but the other is brown/yellow on the truck and grey/red on the vic. i was told to flip-flop them and there was no change once again. Im at a loss and figured id see if you guys could help me before i get another trans or sell the truck. thanks in advance!
Old 08-19-2018, 03:06 PM
The output shaft ring gear is different. 2004 and newer has 24 slots. 2003 and older has 6 holes.
Supposedly, this can be corrected with a custom tune. Refer to the following post (#4 in thread):
https://www.f150online.com/forums/tr...ml#post5235925
You have the opposite issue.
Old 08-19-2018, 03:34 PM
Well, looks like im gonna call SCT or Bama. Im shopping for programmers anyways so if it can fix the issue, then i benefit way more for the same amount of money as a good used trans. Not only that i can pay a little more and use the same tuner for the truck and my Mustang. So if they can, its a win for me. Thanks man!
Old 08-19-2018, 08:40 PM
Read down the other thread to the bottom - Darrin Burch may have some good advice for you, contact him off the forum.
Old 08-19-2018, 11:25 PM
mitymerc's Avatar
shift lever is different too, gotta swap it over.
Old 03-15-2022, 04:47 PM
f150lucas's Avatar
Where did you get your 4r70 from? I'm having trouble locating anywhere in the area right now. Found a remanned 4r70 that these guys have that seems like a deal with free shipping, https://reman-transmission.com/trans...es/?code=4R70W, but I've never done business with it them before so a little sketch.
Quick Reply: 4r70w Trans swap from 04 Crown Vic to 02 F150
